跳转到主内容
Canon SX40 HS Camera Battery Door Contact Replacement
你所需要的
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: 步骤 1 中的图像 1,1
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: 步骤 2 中的图像 1,1
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: 步骤 3 中的图像 1,1
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: 步骤 4 中的图像 1,1
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: 步骤 5 中的图像 1,1
    • Replace either the internal metal battery contact or external battery compartment cover.
结论
John Bui
于03/26/15注册
352 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 的会员
UMASSD-CICHON-S15S7G7
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 813
