跳转到主内容
Canon Powershot SX500 IS LCD Screen Replacement
你所需要的
  1. Canon Powershot SX500 IS LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 步骤 4 中的图像 1,3 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 步骤 4 中的图像 2,3 Canon Powershot SX500 IS LCD Screen Replacement, Back Cover: 步骤 4 中的图像 3,3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 6 中的图像 1,1
  7. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 8 中的图像 1,2 Canon Powershot SX500 IS LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS LCD Screen Replacement, Control Dial: 步骤 9 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS LCD Screen Replacement, LCD Screen: 步骤 13 中的图像 1,1
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
结论
2等其他人完成本指南。
2条评论
Hello, my LCD screen is not working. One day it was fine, the next day I powered my camera and the LCD screen is only half visible. I appreciate the directions on how to take out/repair LCD screen, though where am I able to purchase a new LCD screen for my PowerShot SX500IS? Many thanks.
dana karavias - 回复
Disassembly of SX510HS is exactly the same. No special pry tool is required - it is very easy to remove the cover with your fingernail. Replacement LCD on Aliexpress is 8-12 USD.
Witold Kardyś - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 1,082
