跳转到主内容
Canon Powershot SX500 IS Control Dial Replacement
你所需要的
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: 步骤 2 中的图像 1,1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: 步骤 3 中的图像 1,1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 步骤 4 中的图像 1,3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 步骤 4 中的图像 2,3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 步骤 4 中的图像 3,3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: 步骤 6 中的图像 1,1
  7. Canon Powershot SX500 IS Control Dial Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: 步骤 8 中的图像 1,2 Canon Powershot SX500 IS Control Dial Replacement: 步骤 8 中的图像 2,2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: 步骤 9 中的图像 1,1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: 步骤 10 中的图像 1,1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: 步骤 11 中的图像 1,1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: 步骤 12 中的图像 1,1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
结论
另外一个人完成了本指南。
一条评论
Gracias gracias gracias
edgarlugo20111917 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 443
