跳转到主内容
Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
你所需要的
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: 步骤 1 中的图像 1,1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 2 中的图像 1,2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 3 中的图像 1,3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 3 中的图像 2,3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 3 中的图像 3,3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 4 中的图像 1,2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 步骤 5 中的图像 1,1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
结论
Ellis DeVoe
于04/14/15注册
580 声望
创作了5篇指南
团队
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G12
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 283
