跳转到主内容
Canon Powershot SX30 IS LCD Panel Front Cover Replacement
你所需要的
  1. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Rear Cover: 步骤 1 中的图像 1,1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 2 中的图像 1,2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 3 中的图像 1,3 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 3 中的图像 2,3 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 3 中的图像 3,3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 4 中的图像 1,2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 5 中的图像 1,1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
  6. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Front Cover: 步骤 6 中的图像 1,1
    • Unscrew the 2mm screw on the outer edge of the panel
  7. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 7 中的图像 1,2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 步骤 7 中的图像 2,2
    • Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
    • The panel will fall right off
结论
Ellis DeVoe
于04/14/15注册
580 声望
创作了5篇指南
团队
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G12
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 585
