跳转到主内容
Canon Powershot SX30 IS Battery/SD Card Door Replacement
你所需要的
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: 步骤 1 中的图像 1,1
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: 步骤 2 中的图像 1,2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: 步骤 3 中的图像 1,2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
结论
That's It! Good Job!
Ellis DeVoe
于04/14/15注册
580 声望
创作了5篇指南
团队
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G12
4 名成员
创作了5篇指南
1指南评论
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 21
总计 727
