跳转到主内容
Canon Powershot SX30 IS Back Camera Housing Replacement
你所需要的
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: 步骤 1 中的图像 1,2 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: 步骤 1 中的图像 2,2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 2 中的图像 1,3 Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 2 中的图像 2,3 Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 2 中的图像 3,3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 3 中的图像 1,2 Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 3 中的图像 2,2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 4 中的图像 1,1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 5 中的图像 1,1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 6 中的图像 1,2 Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 6 中的图像 2,2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 7 中的图像 1,1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 8 中的图像 1,1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: 步骤 9 中的图像 1,1
    • Close the back cover, and re-insert appropriate screws.
结论
2等其他人完成本指南。
Ellis DeVoe
于04/14/15注册
580 声望
创作了5篇指南
团队
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 的会员
CPSU-MANESS-S15S5G12
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,380
