跳转到主内容
Canon Powershot SX10 IS LCD Screen Replacement
你所需要的
  1. Canon Powershot SX10 IS LCD Screen Replacement, Lithium Ion Battery: 步骤 1 中的图像 1,1
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS LCD Screen Replacement: 步骤 2 中的图像 1,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 2 中的图像 2,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 1,2 Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: 步骤 3 中的图像 2,2
    • Remove all four screws on the corners of the screen cover.
    • Gently pry open the cover with a fingernail or iFixit opening tool.
  4. Canon Powershot SX10 IS LCD Screen Replacement: 步骤 4 中的图像 1,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 4 中的图像 2,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Remove two screws holding on the cover plate on the pivot.
    • Remove the cover plate using an iFixit opening tool.
    • You may need to loosen the bottom first, then pry on the top of the cover plate.
    • Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
  5. Canon Powershot SX10 IS LCD Screen Replacement: 步骤 5 中的图像 1,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 5 中的图像 2,3 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 5 中的图像 3,3
    • Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
    • The screen and plate will drop after removing the last screw.
  6. Canon Powershot SX10 IS LCD Screen Replacement: 步骤 6 中的图像 1,2 Canon Powershot SX10 IS LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Unlatch the ribbon strip and power wires from the circuit board.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 26
总计 1,222
