本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the screw (2.59 mm) from the bottom of the camera.
Remove the screw (4.08 mm) from the menu button side of the camera.
Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
