跳转到主内容
Canon Powershot SD880 Flash Replacement
你所需要的
  1. Canon Powershot SD880 Flash Replacement, Back Cover: 步骤 1 中的图像 1,3 Canon Powershot SD880 Flash Replacement, Back Cover: 步骤 1 中的图像 2,3 Canon Powershot SD880 Flash Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Flash Replacement, Front Cover: 步骤 2 中的图像 1,3 Canon Powershot SD880 Flash Replacement, Front Cover: 步骤 2 中的图像 2,3 Canon Powershot SD880 Flash Replacement, Front Cover: 步骤 2 中的图像 3,3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
  3. Canon Powershot SD880 Flash Replacement, Top Panel: 步骤 3 中的图像 1,2 Canon Powershot SD880 Flash Replacement, Top Panel: 步骤 3 中的图像 2,2
    • Unplug the green and white plugs that connect the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the tab at the back.
  4. Canon Powershot SD880 Flash Replacement, LCD Display: 步骤 4 中的图像 1,3 Canon Powershot SD880 Flash Replacement, LCD Display: 步骤 4 中的图像 2,3 Canon Powershot SD880 Flash Replacement, LCD Display: 步骤 4 中的图像 3,3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
  5. Canon Powershot SD880 Flash Replacement, Flash: 步骤 5 中的图像 1,3 Canon Powershot SD880 Flash Replacement, Flash: 步骤 5 中的图像 2,3 Canon Powershot SD880 Flash Replacement, Flash: 步骤 5 中的图像 3,3
    • Use caution when removing the flash, as the capacitor may still have a charge.
    • Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
    • To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
    • Disconnect the white plug from the red and black wires.
结论
Robert Manno
于01/05/11注册
432 声望
创作了4篇指南
团队
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 2,564
