跳转到主内容
Canon Powershot SD880 Back Cover Replacement
你所需要的
  1. Canon Powershot SD880 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Canon Powershot SD880 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Canon Powershot SD880 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
结论
另外一个人完成了本指南。
Ben Tupas
于01/13/11注册
317 声望
创作了3篇指南
团队
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G3
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,713
