跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Take off outer cover, detach cable, and remove Release Button.
  1. Squeeze the sides of the plastic connector while gently detaching the cable. Your shutter release button is now removed and can be replaced. The shutter release button assembly should only be attached by a small red and black wire, with a plastic connector at the end.
    • Squeeze the sides of the plastic connector while gently detaching the cable. Your shutter release button is now removed and can be replaced.
    • The shutter release button assembly should only be attached by a small red and black wire, with a plastic connector at the end.
  2. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
结论
Stanley
于2011年01月30日注册
372 信誉积分
创作了4篇指南
团队
Cal Poly, Team 4-33, Regan Winter 2011 Cal Poly, Team 4-33, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G33
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 908
