跳转到主内容
Canon Powershot SD790 IS LCD Screen Replacement
你所需要的
  1. Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove the two screws from the left side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the right side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 2 中的图像 1,2 Canon Powershot SD790 IS LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Using your fingers, manually open the USB cover, labeled as “A/V OUT DIGITAL.”
    • Gently pull the tab of the side cover, completely detaching the cover from the camera.
  3. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon Powershot SD790 IS LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon Powershot SD790 IS LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Gently grab the sides of the camera and pry off the screen cover using your fingers.
    • If necessary, use a spudger.
    • Once the screen cover is removed, the front cover and side plate will slide off.
  4. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 4 中的图像 1,2 Canon Powershot SD790 IS LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the screw located below the button release panel.
  5. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, gently slide the LCD cable, horizontally from its white plug towards the camera screen.
  6. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Caution: Do not completely remove the button release panel from the camera. The black and red cables will keep the panel attached to the camera. Allow the panel to hang out of the way as you complete the remaining steps.
    • Using your fingers, open the USB port cover (labeled as “A/V OUT DIGITAL” on the camera).
    • Using your fingers, remove the button release panel located on the top of the camera and allow room for it to hang out of the way.
  7. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 7 中的图像 1,2 Canon Powershot SD790 IS LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Using the spudger, flip the clip in an upward motion. The clip should remain attached to camera, not removed completely.
  8. Canon Powershot SD790 IS LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Using tweezers, gently slide the orange, translucent LCD ribbon from its dark gray plug horizontally towards the screen.
    • Remove the screen from the camera, and attach the new screen.
结论
3等其他人完成本指南。
Gabriela
于01/11/11注册
150 声望
撰写一个指南
团队
Cal Poly, Team 4-33, Regan Winter 2011 Cal Poly, Team 4-33, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G33
4 名成员
创作了5篇指南
1指南评论
do I just put everyhting back together in the backwards order of how I took it off?
zion saez - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 4,290
