跳转到主内容
Canon Powershot SD790 IS Disassembly
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: 步骤 1 中的图像 1,3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: 步骤 1 中的图像 2,3 Canon Powershot SD790 IS Disassembly, Canon Powershot SD790 IS: 步骤 1 中的图像 3,3
    • 1. Use a Phillips #0 screwdriver to remove the six screws from the sides of the camera. 2. Hold the mini-USB cover open. Gently grip and remove the side cover. 3. Grip the camera from the sides and carefully remove the screen cover.
  2. Canon Powershot SD790 IS Disassembly: 步骤 2 中的图像 1,2 Canon Powershot SD790 IS Disassembly: 步骤 2 中的图像 2,2
    • Hold the mini-USB cover open.
    • Gently grip and remove the side cover.
  3. Canon Powershot SD790 IS Disassembly: 步骤 3 中的图像 1,3 Canon Powershot SD790 IS Disassembly: 步骤 3 中的图像 2,3 Canon Powershot SD790 IS Disassembly: 步骤 3 中的图像 3,3
    • Grip the camera from the sides and carefully remove the screen cover.
    • Start at the bottom edge and slowly lift up the cover.
    • Be very careful removing the cover in the area with the camera/video switch.
    • Remove the front cover while continuing to grip the sides of the camera.
    • After removing the screen cover, remove the screw by the power switch that anchors the side plate to separate the sides from the camera.
结论
3等其他人完成本指南。
Stanley
于01/30/11注册
372 声望
创作了4篇指南
团队
Cal Poly, Team 4-33, Regan Winter 2011 Cal Poly, Team 4-33, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G33
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 5,299
