当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the three 3.8 mm screws from the underside of the camera.
Each of the screws is slightly different, so it is important that you note the original location of each screw.
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
One of these screws is hidden under the USB port cover.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
After disconnecting both cables, pull the screen away from the camera to remove it.
Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
After the cable is unlocked, it easily pulls free.
In order to remove the photo sensor, you will have to cut through glue and remove screws.
Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
WARNING: Knives are sharp. Treat them with respect.
Now remove the three .15 inch screws holding the photo sensor to the camera frame.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
