当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the grey latch to open the battery compartment.
Push and slide the orange retaining clip to the right to remove the battery.
Remove battery from the camera.
Remove the lanyard.
Position the camera so that the bottom is facing up.
Remove the two 2.3mm screws beneath the name plate.
Remove the two 2.8 mm screws surrounding the threaded tripod mount.
Remove the 3.8mm screw from the back face of the camera.
Remove the two 2.3mm screws from the right face of the camera.
Remove the two outer 3.2mm screws from the left side of the camera
Remove the two inner 3.7mm screws from the left side of the camera.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
Remove the CF card door from the left side of the camera body.
Slide the rubber digital a/v cap out of place on the front plate.
Remove the front face by sliding it off.
Remove the rubber seal that covers the right side of the viewfinder.
Remove the two 3.9mm screws that hold the laminated copper sheet.
Remove the wire connections that connect along the bottom of the motherboard.
Remove the single 3.8mm screw that is on the motherboard.
Remove the motherboard from the main frame of the camera body.
After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
Unsolder the four points at the top of the screen with a soldering iron
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于04/13/11注册
148 声望
撰写一个指南
徽章: 4
+1个徽章
CPSU-WALTERS-S11S20G70
5 名成员
创作了4篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 1,537
