跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon Powershot S200 Motherboard Replacement
你所需要的
  1. Canon Powershot S200 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Canon Powershot S200 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: 步骤 2 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Be careful to keep track of the different screw sizes as you proceed with this guide.
    • Find the bottom face of the camera. Remove the two 2.3mm screws beneath the name plate and the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two center 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: 步骤 10 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: 步骤 11 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the two 3.9mm screws that hold the laminated cooper sheet.
  15. Canon Powershot S200 Motherboard Replacement: 步骤 15 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the seven wire connections that connect to the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Carefully remove the motherboard from the main frame of the camera body.
结论
Orlando Zuniga
于04/14/11注册
11 声望
撰写一个指南
团队
Cal Poly, Team 20-70, Walters Spring 2011 Cal Poly, Team 20-70, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G70
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,879
