跳转到主内容
Canon Powershot S200 Motherboard Replacement
你所需要的
  1. Canon Powershot S200 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Canon Powershot S200 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: 步骤 2 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: 步骤 10 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: 步骤 11 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: 步骤 15 中的图像 1,2 Canon Powershot S200 Motherboard Replacement: 步骤 15 中的图像 2,2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the motherboard from the main frame of the camera body.
结论
Orlando Zuniga
于04/14/11注册
11 声望
撰写一个指南
团队
Cal Poly, Team 20-70, Walters Spring 2011 Cal Poly, Team 20-70, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G70
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,904
