当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Position the camera so that the bottom is facing up.
Remove the two 2.3mm screws beneath the name plate.
Remove the two 2.8 mm screws surrounding the threaded tripod mount.
Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
Carefully remove the lens.
Remove the bottom side of the lens first before the viewfinder side.
Be careful of wires and delicate parts.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
