跳转到主内容
Canon Powershot S110 Option Dial Replacement
你所需要的
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: 步骤 1 中的图像 1,2 Canon Powershot S110 Option Dial Replacement, Option Dial: 步骤 1 中的图像 2,2
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: 步骤 2 中的图像 1,3 Canon Powershot S110 Option Dial Replacement: 步骤 2 中的图像 2,3 Canon Powershot S110 Option Dial Replacement: 步骤 2 中的图像 3,3
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: 步骤 3 中的图像 1,1
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: 步骤 4 中的图像 1,2 Canon Powershot S110 Option Dial Replacement: 步骤 4 中的图像 2,2
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: 步骤 6 中的图像 1,1
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: 步骤 7 中的图像 1,2 Canon Powershot S110 Option Dial Replacement: 步骤 7 中的图像 2,2
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
结论
2等其他人完成本指南。
akac92
于07/14/15注册
298 声望
创作了2篇指南
团队
UW Tacoma, Team 1-2, Liner SU 2015 UW Tacoma, Team 1-2, Liner SU 2015 的会员
UWT-LINER-SU15S1G2
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,143
