跳转到主内容
加入维修社区 - 创建账户
Canon Powershot Pro1 Motherboard Replacement
你所需要的
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: 步骤 2 中的图像 1,1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: 步骤 3 中的图像 1,1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 1,3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 2,3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: 步骤 6 中的图像 1,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 6 中的图像 2,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: 步骤 7 中的图像 1,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 7 中的图像 2,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 7 中的图像 3,3
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: 步骤 8 中的图像 1,2 Canon Powershot Pro1 Motherboard  Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: 步骤 9 中的图像 1,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 9 中的图像 2,3 Canon Powershot Pro1 Motherboard  Replacement: 步骤 9 中的图像 3,3
    • Once detached from all connectors and ribbon cables, remove the motherboard.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 62
总计 1,370
