跳转到主内容
加入维修社区 - 创建账户
Canon Powershot Pro1 Flash Replacement
你所需要的
  1. Canon Powershot Pro1 Flash Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: 步骤 2 中的图像 1,1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: 步骤 3 中的图像 1,1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: 步骤 4 中的图像 1,1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: 步骤 5 中的图像 1,2 Canon Powershot Pro1 Flash Replacement, Flash: 步骤 5 中的图像 2,2
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: 步骤 6 中的图像 1,1
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: 步骤 7 中的图像 1,1
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: 步骤 8 中的图像 1,3 Canon Powershot Pro1 Flash Replacement: 步骤 8 中的图像 2,3 Canon Powershot Pro1 Flash Replacement: 步骤 8 中的图像 3,3
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: 步骤 9 中的图像 1,1
    • Cut the flash and capacitor cables with a wire cutter.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 22
过去 30 天: 58
总计 1,189
