当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
Keep track of all the screws that are being taken out from the outer case.
The display screen of the camera should be facing towards you.
Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
With the screen still facing you, rotate the camera 180 degrees.
The side with the charging port should now be facing up.
Use the Philips #00 screwdriver to pry open the charging port cover.
Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
Remove both 3.1 mm screws using the Phillips #00 screwdriver.
The image still shows the screw from step 3 in place.
Turn the camera so the bottom is once again facing up.
With the battery door still open, use a spudger to remove the cover from the front of the camera.
Carefully go around all of the edges until the cover is released.
Just like Step 4-6 , carefully use the Spudger to remove the back cover.
Go along all the borders of the back cover so that it releases from the camera safely.
Be careful not to break the tabs.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
