跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon Powershot ELPH 100 HS Outer Case Replacement
你所需要的
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Remove the two 3.1mm screws from the bottom of the camera.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 2 中的图像 1,1
    • With the screen facing you, rotate the camera counter clock-wise onto it's side.
    • Remove the two 3.1mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 3 中的图像 1,1
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 4 中的图像 1,2 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 4 中的图像 2,2
    • Use the tool (or fingers) to pry open the charging port cover.
    • Rotate the cover so that you have access to the screw underneath.
    • Remove both 3.1mm screws.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 5 中的图像 1,2 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 5 中的图像 2,2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 6 中的图像 1,1
    • Pull off the the front cover.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 1,3 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 2,3 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 3,3
    • Use the spudger to remove the back cover.
    • Be careful not to break the tabs.
结论
5等其他人完成本指南。
Jacob
于03/17/15注册
561 声望
创作了3篇指南
团队
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G10
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,582
