跳转到主内容
Canon Powershot ELPH 100 HS Outer Case Replacement
你所需要的
  1. Canon Powershot ELPH 100 HS Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  2. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 2 中的图像 1,1
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  3. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 3 中的图像 1,2 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 3 中的图像 2,2
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  4. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 4 中的图像 1,2 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 4 中的图像 2,2
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  5. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 5 中的图像 1,2 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 5 中的图像 2,2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  6. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 6 中的图像 1,1
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  7. Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 1,3 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 2,3 Canon Powershot ELPH 100 HS Outer Case Replacement: 步骤 7 中的图像 3,3
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
结论
6等其他人完成本指南。
Jacob
于03/17/15注册
570 声望
创作了3篇指南
团队
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G10
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 24
总计 1,676
