跳转到主内容
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 步骤 1 中的图像 1,3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 步骤 1 中的图像 2,3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: 步骤 2 中的图像 1,2 Canon Powershot ELPH 100 HS Memory Card Replacement: 步骤 2 中的图像 2,2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 步骤 3 中的图像 1,3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 步骤 3 中的图像 2,3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 步骤 3 中的图像 3,3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
结论
Lillia
于03/17/15注册
255 声望
创作了2篇指南
团队
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G10
2 名成员
创作了5篇指南
一条评论
my internal card reader hardware is not functional
can i replace it somehow
s l - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 33
总计 1,028
