简介
This guide will show you how to remove your camera's memory card when you need to transfer pictures. If the memory card is malfunctioning in any way, you can also use this guide to install a new memory card.
Locate the battery cover on the bottom of your camera.
Slide the tab to the right to open the battery cover.
Push down on the memory card until it clicks and releases.
Pull up on the memory card to remove it.
即将完成!
结论
