当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Have a small Phillips-head screwdriver and extender, an opening tool, and a soldering iron to complete the following steps.
Keep the screws organized and separated as you remove them.
With the screen facing toward you, the battery slot can be found under the right side of the camera.
Remove all batteries and leave the slot open.
Inside the battery slot, there are another 3 screws located at the very bottom of each slot.
To reach these screws and remove them, attach the screwdriver extender to the #00 Phillips-head screwdriver.
Using the pry tool, pry the top of the camera open.
Be sure not to apply too much force and damage the wires under the lid.
The top should dangle loosely from the camera and not be fully detached.
Once the top is loose, locate the 2 screws near the AV outlet.
Remove both screws.
The removal of the 2 screws will allow you to remove the plastic AV covering.
Once the AV cover is removed, there will be 1 more screw left to remove.
Locate the black film under the flash unit and remove the screw holding it in place.
Once the screw is removed, gently wiggle the flash out of place without damaging any internal parts.
Once the second film is removed and has revealed the flash wires, proceed to unsolder the necessary wires in order to detach the flash.
Take the new flash and solder it where the old one was removed.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
