跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon Powershot A70 Rear Exterior Panel Replacement
你所需要的
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: 步骤 1 中的图像 1,1
    • Unscrew the three small screws on the bottom of the camera.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the screw in the CF compartment.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 3 中的图像 1,3 Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 3 中的图像 2,3 Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 3 中的图像 3,3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with the IFIXIT opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 4 中的图像 1,2 Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 4 中的图像 2,2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: 步骤 5 中的图像 1,1
    • The interior of the camera should look like this.
结论
Shalan Ertis
于01/26/10注册
68 声望
创作了3篇指南
团队
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G40
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 3,255
