当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
The panel that holds the shutter button and zoom will come off.
Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
Open the rubber Digital AV Out compartment flap.
Pry the battery with an opening tool.
Carefully pull out the battery with two fingers.
Remove the two screws that are now visible with a Phillips #00 screwdriver.
Starting from the bottom, carefully pull the casing off.
The casing will now pivot at the top.
There are three catches that hold the back casing to the body.
You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
Remove the viewfinder with a firm pull directly upwards.
With tweezers, carefully unplug the two small wires from the green plug.
Carefully replace the broken speaker/shutter panel with a new one.
Hold the flex assembly gently but firmly, and pull it out of the connection with two fingers.
Be sure to pull straight up, not at an angle.
The screen should no longer be screwed to the body.
Gently push the screen down and then pull it away from the body of the camera.
It will swing away, because it is still plugged into the camera.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
