跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Canon Powershot A70 Front Exterior Panel Disassembly
你所需要的
  1. Canon Powershot A70 Front Exterior Panel Disassembly, Shutter/Speaker Panel: 步骤 1 中的图像 1,1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 2 中的图像 1,2 Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 2 中的图像 2,2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Front Exterior Panel Disassembly, Rear Exterior Panel: 步骤 3 中的图像 1,1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 4 中的图像 1,1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 5 中的图像 1,3 Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 5 中的图像 2,3 Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 5 中的图像 3,3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 6 中的图像 1,2 Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 6 中的图像 2,2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 7 中的图像 1,1
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Front Exterior Panel Disassembly, Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 8 中的图像 1,1
    • Remove the two screws at the top of the battery compartment.
  9. Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 9 中的图像 1,2 Canon Powershot A70 Front Exterior Panel Disassembly: 步骤 9 中的图像 2,2
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
结论
2等其他人完成本指南。
Brian
于01/26/10注册
102 声望
创作了2篇指南
团队
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G40
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,392
