当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
Open the digital A/V DC terminal cover.
Remove the three 4 mm screws.
Detach the digital A/V DC terminal.
When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
Open the battery cover.
With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
Apply some force, but pull the front case gently to prevent damage.
Flip the LCD screen all the way open.
Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
Using your forefinger and thumb, pull the flash unit upward, and out of the camera.
The flash unit capacitor may cause electric shocks. Do not touch both metallic ends of the capacitor simultaneously.
Unsolder the white, yellow, brown, and green wires at their soldering points.
Remove and replace the flash assembly.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
