跳转到主内容
Canon Powershot A3300 IS Motherboard Replacement
你所需要的
  1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Motherboard Replacement: 步骤 2 中的图像 1,2 Canon Powershot A3300 IS Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: 步骤 3 中的图像 1,2 Canon Powershot A3300 IS Motherboard Replacement, Front Cover: 步骤 3 中的图像 2,2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 Canon Powershot A3300 IS Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the black cover to expose the motherboard.
  5. Canon Powershot A3300 IS Motherboard Replacement: 步骤 5 中的图像 1,2 Canon Powershot A3300 IS Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the shutter button located at the top left of the camera.
    • This will expose the screws that need to be removed.
  6. Canon Powershot A3300 IS Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
  7. Canon Powershot A3300 IS Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the 1.6mm screw at the top of the camera.
  8. Canon Powershot A3300 IS Motherboard Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull out brown flat flexible wires from their connection.
    • Remember to gently wiggle the wires from the connection since they are very fragile connectors.
  9. Canon Powershot A3300 IS Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the last 1.2mm screw to pull out the motherboard.
    • The motherboard should freely separate from the housing.
  10. Canon Powershot A3300 IS Motherboard Replacement: 步骤 10 中的图像 1,3 Canon Powershot A3300 IS Motherboard Replacement: 步骤 10 中的图像 2,3 Canon Powershot A3300 IS Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove motherboard and replace with a new one.
结论
Phillip Chen
于10/17/17注册
440 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 33
总计 469
