跳转到主内容
Canon PowerShot SX600 HS Display Screen Replacement
你所需要的
  1. Canon PowerShot SX600 HS Display Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 2 中的图像 1,1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX600 HS Display Screen Replacement: 步骤 3 中的图像 2,2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Display Screen Replacement, Power and Shutter Buttons: 步骤 4 中的图像 1,1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 7 中的图像 1,2 Canon PowerShot SX600 HS Display Screen Replacement: 步骤 7 中的图像 2,2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 8 中的图像 1,1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: 步骤 9 中的图像 1,2 Canon PowerShot SX600 HS Display Screen Replacement, Display Screen: 步骤 9 中的图像 2,2
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 11 中的图像 1,1
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 12 中的图像 1,1
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Display Screen Replacement: 步骤 13 中的图像 1,1
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
结论
7等其他人完成本指南。
Jennyfer Munoz
于02/15/17注册
411 声望
创作了3篇指南
团队
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017 的会员
USFT-LACY-S17S6G4
3 名成员
创作了9篇指南
2条评论
Plz I want othe
Gihan - 回复
I did all this with a new LCD. After reassemble the lens has extended out but camera does not turn on. Should I take it apart again and start from beginning. Is there a connector not in place correctly that will cause this to happen?
Bill Graham - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 4,501
