跳转到主内容
Canon PowerShot SX530 HS Shutter Release Cover Replacement
你所需要的
  1. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
  2. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 2 中的图像 1,1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
  3. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Canon PowerShot SX530 HS Back Panel Assembly: 步骤 3 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement, Canon PowerShot SX530 HS Back Panel Assembly: 步骤 3 中的图像 2,2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
  4. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 4 中的图像 2,2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
  5. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 5 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 5 中的图像 2,2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
  6. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 6 中的图像 1,3 Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 6 中的图像 2,3 Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 6 中的图像 3,3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
  7. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Internal Button Sensor Plate: 步骤 7 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement, Internal Button Sensor Plate: 步骤 7 中的图像 2,2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
  8. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 8 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 8 中的图像 2,2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
  9. Canon PowerShot SX530 HS Shutter Release Cover Replacement, LCD Display: 步骤 9 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement, LCD Display: 步骤 9 中的图像 2,2
    • Locate the Display screen in the center of the camera.
    • Use a plastic opening tool to pry off the LCD screen. Start on the bottom left corner—this is the furthest away from the ribbon holding it down on the right side.
    • The adhesive holding down the display should be strong enough to put the display back on.
  10. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 10 中的图像 1,1
  11. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Shutter Back Cover: 步骤 11 中的图像 1,1
    • Remove the two screws (5-6mm) on the left and right side of the shutter panel with a Phillips PH000 screwdriver.
  12. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 12 中的图像 1,1
    • Lift the shutter light and pull the shutter back panel off the camera.
    • Be careful when pulling out the panel because it is connected to the motherboard.
  13. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Internal Metal Frame: 步骤 13 中的图像 1,2 Canon PowerShot SX530 HS Shutter Release Cover Replacement, Internal Metal Frame: 步骤 13 中的图像 2,2
    • Use a PH000 screwdriver to remove the four 3.5 mm screws holding the plate in place.
    • Use a PH000 screwdriver to remove the two 2.5 mm screws holding the top of the plate.
    • Use a PH000 screwdriver to remove the two 4.5 mm screws connecting the plate to the motherboard.
  14. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 14 中的图像 1,1
    • Gently pull the plate up and away from the camera.
    • Part of the plate extends inside the camera beneath the shutter, so be sure to not angle the plate as you pull.
  15. Canon PowerShot SX530 HS Shutter Release Cover Replacement, Shutter Release Cover: 步骤 15 中的图像 1,3 Canon PowerShot SX530 HS Shutter Release Cover Replacement, Shutter Release Cover: 步骤 15 中的图像 2,3 Canon PowerShot SX530 HS Shutter Release Cover Replacement, Shutter Release Cover: 步骤 15 中的图像 3,3
    • Hold the camera by the bottom or place the camera on a firm flat surface and keep a firm grip on the device.
    • Once a comfortable hold is established, gently pull the cover towards the rear of the camera. Then lift directly upwards on the cover to remove it.
    • Do not pull the cover off too hard to the point that you might accidentally tug on the ribbon tape.
  16. Canon PowerShot SX530 HS Shutter Release Cover Replacement: 步骤 16 中的图像 1,1
    • Once the cover is loose from the device, use a plastic opening tool to unlock the ribbon tape.
结论
另外一个人完成了本指南。
Aaron Aussendorf
于02/02/17注册
122 声望
撰写一个指南
团队
USF Tampa, Team 16-4, Blackwell Spring 2017 USF Tampa, Team 16-4, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 816
