跳转到主内容
Canon PowerShot SX530 HS Back Panel Assembly
你所需要的
  1. Canon PowerShot SX530 HS Back Panel Assembly, Canon PowerShot SX530 HS Back Panel Assembly: 步骤 1 中的图像 1,2 Canon PowerShot SX530 HS Back Panel Assembly, Canon PowerShot SX530 HS Back Panel Assembly: 步骤 1 中的图像 2,2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
  2. Canon PowerShot SX530 HS Back Panel Assembly: 步骤 2 中的图像 1,2 Canon PowerShot SX530 HS Back Panel Assembly: 步骤 2 中的图像 2,2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
  3. Canon PowerShot SX530 HS Back Panel Assembly: 步骤 3 中的图像 1,2 Canon PowerShot SX530 HS Back Panel Assembly: 步骤 3 中的图像 2,2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
  4. Canon PowerShot SX530 HS Back Panel Assembly: 步骤 4 中的图像 1,3 Canon PowerShot SX530 HS Back Panel Assembly: 步骤 4 中的图像 2,3 Canon PowerShot SX530 HS Back Panel Assembly: 步骤 4 中的图像 3,3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
结论
2等其他人完成本指南。
Xavier Patrick
于02/02/17注册
481 声望
创作了3篇指南
团队
USF Tampa, Team 16-4, Blackwell Spring 2017 USF Tampa, Team 16-4, Blackwell Spring 2017 的会员
USFT-BLACKWELL-S17S16G4
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 924
