跳转到主内容
Canon PowerShot SX520 HS Motherboard Replacement
你所需要的
  1. Canon PowerShot SX520 HS Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 2 中的图像 1,1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 步骤 3 中的图像 1,3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 步骤 3 中的图像 2,3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 步骤 3 中的图像 3,3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 5 中的图像 1,2 Canon PowerShot SX520 HS Motherboard Replacement: 步骤 5 中的图像 2,2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 6 中的图像 1,1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Motherboard Replacement, LCD Screen: 步骤 7 中的图像 1,1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 步骤 9 中的图像 1,3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 步骤 9 中的图像 2,3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 步骤 9 中的图像 3,3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Motherboard Replacement, Lens: 步骤 10 中的图像 1,1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift up the lens by grabbing the sides with your fingers.
  12. Canon PowerShot SX520 HS Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove 1-2.5 mm screw using a Phillips #000 screwdriver.
  13. Canon PowerShot SX520 HS Motherboard Replacement: 步骤 13 中的图像 1,2 Canon PowerShot SX520 HS Motherboard Replacement: 步骤 13 中的图像 2,2
    • Disconnect the two orange serial cables at the top of the motherboard using your fingers.
    • Gently remove the motherboard using your fingers.
    • Too much force will break the motherboard.
结论
3等其他人完成本指南。
Kyle Crowley
于09/22/15注册
337 声望
创作了3篇指南
团队
Baylor, Team 4-4, Williams Fall 2015 Baylor, Team 4-4, Williams Fall 2015 的会员
BU-WILLIAMS-F15S4G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 908
