简介
If your camera is physically damaged, it's possible that the motherboard was affected as well. This page is a step-by-step guide on how to remove and replace the motherboard.
你所需要的
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
After all 8 screws are removed, pull the metal plate out with your fingers.
Unlcip the large cable by pulling up on the metal part with your finger.
Slide out the 2 smaller cables with your fingers.
3等其他人完成本指南。
