跳转到主内容
Canon PowerShot SX260 HS LCD Screen Replacement
你所需要的
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 3 中的图像 1,1
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 6 中的图像 1,1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Gently slide the LCD screen to the right and remove.
结论
3等其他人完成本指南。
Tyler Kelch
于03/05/15注册
622 声望
创作了4篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 4,315
