跳转到主内容
Canon PowerShot SX260 HS Flash Assembly Replacement
你所需要的
  1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 1,3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 2,3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 3,3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 screws on the left side.
    • Remove the 2 screws on the bottom of the camera.
    • Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 2 中的图像 1,1
    • Use your plastic opening tool to gently lift and remove the back face plate.
  3. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 3 中的图像 1,1
    • After removing the exterior screws, use your fingers to gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 4 中的图像 1,1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  5. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 5 中的图像 1,1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  6. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 6 中的图像 1,1
    • Next, you will need to remove the dial panel by removing the 2 (3mm) screws on the back side of the camera.
    • Gently remove the dial panel with your fingers.
  7. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 7 中的图像 1,2 Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 7 中的图像 2,2
    • Remove 1 (3 mm) screw from the flash generator with a Phillips screw driver
    • Gently lift the flash generator off of the camera with the plastic opening tool .
  8. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Gently unplug the ribbon cable with your tweezers.
    • Be careful not to rip it.
  9. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 9 中的图像 1,2 Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 9 中的图像 2,2
    • Using your plastic opening tool to gently move the plug lock from the end of the ribbon cord by lifting it upward.
    • Gently remove the ribbon cable from the connector with tweezers.
  10. Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 10 中的图像 1,2 Canon PowerShot SX260 HS Flash Assembly Replacement: 步骤 10 中的图像 2,2
    • Gently remove the ribbon cable assembly from the top of the camera with your tweezers.
    • This cable is a long piece that runs across the top of the camera.
    • The flash assembly is connected to this cable.
    • Once removed gently lift out of the camera
    • Replace the ribbon cable with the attached flash assembly.
结论
另外一个人完成了本指南。
Tyler Kelch
于03/05/15注册
622 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 30
总计 1,722
