跳转到主内容
Canon PowerShot SX260 HS Battery Replacement
你所需要的
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX260 HS Battery Replacement: 步骤 2 中的图像 2,2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: 步骤 3 中的图像 1,1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
结论
Tyler Kelch
于03/05/15注册
622 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,062
