跳转到主内容
Canon PowerShot SX160 IS Shutter Button Replacement
你所需要的
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 1,3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 2,3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 3,3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Shutter Button Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS Shutter Button Replacement: 步骤 3 中的图像 2,2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Locate and replace the shutter button on the front panel of the camera.
结论
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Jamie Secretan
于03/11/15注册
1,962 声望
创作了6篇指南
团队
一条评论
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 2,884
