跳转到主内容
Canon PowerShot SX160 IS Outer Case Replacement
你所需要的
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS Outer Case Replacement: 步骤 2 中的图像 2,2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS Outer Case Replacement: 步骤 3 中的图像 2,2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
    Its missed here, but there are two screws, silver, that are in the flash that need to be taken out, open the flash mechanism and you will see them.
    climbingfish - 回复
    Do not!! Pull the front cover off there is a ribbon cable attached in the top right corner , prise it off gently. This bastard cost me my camera.
    climbingfish - 回复
结论
2等其他人完成本指南。
Jamie Secretan
于03/11/15注册
1,990 声望
创作了6篇指南
团队
1指南评论
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 37
总计 1,983
