跳转到主内容
Canon PowerShot SX160 IS Outer Case Replacement
你所需要的
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS Outer Case Replacement: 步骤 2 中的图像 2,2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS Outer Case Replacement: 步骤 3 中的图像 2,2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
结论
2等其他人完成本指南。
Jamie Secretan
于03/11/15注册
1,962 声望
创作了6篇指南
团队
一条评论
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,791
