跳转到主内容
Canon PowerShot SX160 IS Function Wheel Replacement
你所需要的
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 步骤 1 中的图像 1,3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 步骤 1 中的图像 2,3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: 步骤 1 中的图像 3,3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS Function Wheel Replacement: 步骤 2 中的图像 2,2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS Function Wheel Replacement: 步骤 3 中的图像 2,2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: 步骤 4 中的图像 1,1
    • Remove and replace the function wheel.
结论
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
于03/11/15注册
1,990 声望
创作了6篇指南
团队
一条评论
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 621
