跳转到主内容
Canon PowerShot SX160 IS Format Wheel Replacement
你所需要的
  1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: 步骤 1 中的图像 1,2 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: 步骤 1 中的图像 2,2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
    • The screws are located directly above the LCD screen.
  2. Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 2 中的图像 2,2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
  3. Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 3 中的图像 2,2
    • Use your hands to gently separate the back plate from the camera.
    • Slowly pull off the camera plate until it fully detaches from the camera.
  4. Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 4 中的图像 2,2
    • Use your hands to gently separate the front plate from the camera.
  5. Canon PowerShot SX160 IS Format Wheel Replacement: 步骤 5 中的图像 1,1
    • Locate and replace the format wheel on the front panel of the camera.
结论
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
于03/11/15注册
1,962 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 665
