跳转到主内容
Canon PowerShot SX150 IS Screen Replacement
你所需要的
  1. Canon PowerShot SX150 IS Screen Replacement, Screen: 步骤 1 中的图像 1,3 Canon PowerShot SX150 IS Screen Replacement, Screen: 步骤 1 中的图像 2,3 Canon PowerShot SX150 IS Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove the 2 outer 5mm screws using the size J000 screwdriver.
    • Remove the one 5mm screw on the left and the two 4mm screws on the bottom.
    • Remove the two 2mm screws located above the screen on the back of the camera.
  2. Canon PowerShot SX150 IS Screen Replacement: 步骤 2 中的图像 1,3 Canon PowerShot SX150 IS Screen Replacement: 步骤 2 中的图像 2,3 Canon PowerShot SX150 IS Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the plastic panel surrounding the screen. (it should pop off easily)
    • Remove the one 5mm screws on the right using the size J000 screw driver from the button plate. Remove the two 4mm screws on the left, then move the button plate out of the way.
    • carefully unlatch and then detach the button plat's flex ribbon from the motherboard.
  3. Canon PowerShot SX150 IS Screen Replacement: 步骤 3 中的图像 1,1
    • Lift the flex ribbon lock gently with your finger.
  4. Canon PowerShot SX150 IS Screen Replacement: 步骤 4 中的图像 1,2 Canon PowerShot SX150 IS Screen Replacement: 步骤 4 中的图像 2,2
    • Use the tweezers to carefully detach the screen’s flex ribbon from the circuit board.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
  5. Canon PowerShot SX150 IS Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
  6. Canon PowerShot SX150 IS Screen Replacement: 步骤 6 中的图像 1,1
    • Lift the screen out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 633
