简介
This guide will take you through the steps needed to replace the Digital Image Sensor in your Cannon PowerShotSX150 IS. This can be used to fix blurry images if your problem appears to be the Digital Image Sensor.
你所需要的
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two 2mm screws above the screen using the size J000 screwdriver.
Lift the two flex ribbons with your tweezers and remove them.
Move the circuit board to the side.
2等其他人完成本指南。
