跳转到主内容
Canon PowerShot SX150 IS Buttons Replacement
你所需要的
  1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: 步骤 1 中的图像 1,3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: 步骤 1 中的图像 2,3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: 步骤 1 中的图像 3,3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: 步骤 2 中的图像 1,3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: 步骤 2 中的图像 2,3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: 步骤 2 中的图像 3,3
    • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
    • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
  3. Canon PowerShot SX150 IS Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
  4. Canon PowerShot SX150 IS Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove back plate from the camera and locate the orange button plate to the right of the screen.
  5. Canon PowerShot SX150 IS Buttons Replacement: 步骤 5 中的图像 1,3 Canon PowerShot SX150 IS Buttons Replacement: 步骤 5 中的图像 2,3 Canon PowerShot SX150 IS Buttons Replacement: 步骤 5 中的图像 3,3
    • Once the back plate is removed. Locate the buttons to the right of the screen.
    • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
    • After lifting the tabs the buttons should come right off, then replace with the new button.
结论
一条评论
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 531
