简介
First remove the back casing and control dial before attempting to remove buttons.
配件
没有特定配件。
Turn the camera to the side that has the screen.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Turn the camera with the lens facing down.
Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
Keep making pressure and slowly slide the opening tool through all the gap.
There is one point when the cover will disassemble completely.
Once you have removed the back cover this is what the camera will look like.
Locate the Control Dial.
Once casing and control dial have been removed, you will begin removing silicone button pad.
Use tweezers to grip the edge of the silicone pad and begin lifting upward.
